We have work with new Rotork Actuator model: IQ35FA13A, after it installed in the 4 way valve and it configured (the open/close limit set as well), in the local mode the actuator works properly but when it switch to remote mode it doesn't work at all, many investigation performed to resolve this situation but it failed,
As the circuit diagram attached the remote module needs a 125VDC as an external command, on the other side the command provided from the CPU is 24VDC,
This status (the actuator needs 125vdc to work remotely), still not confirmed!!
Please any one has an experience with this kid of actuator to help me to confirm the actuator needs a 125 VDC to work remotely ,
In the attached you can find a manufacturer plate, actuator photos and circuit diagram
Laid86
Laid86
