Z
i've 10 GE relays of types 750, 369, 469 and 480 in one loop. the issue is more likely to be a communication issue.
After some time master station stops polling data from one of the relays connected in that loop and then after a small fraction of time (4 to 8 seconds) it comes back to normal.
when i checked the absolute voltage between + and - wires of RS 485 cable it shows 1.5 volts whereas when i checked the volts level on other loops, it shows 2.5...
does it sound a familiar issue to anyone out there, or think the voltage level might causing this issue of regular failover.
