I'm currently trying to establish a remote console connection to a Cisco 3750x switch via a tripp lite console server B096 doing RS232 over fiber conversion. I have several remote switches directly connected to this TRIPP Lite, and those all work fine using putty and reverse telnet or ssh to the tripp lite port that they are attached or via the tripp lite web interface.
My problem device is a 3750x switch in another building a few miles away, which I have attached a Serialcom Fiber to RS232 convertor (Single Mode).
There is one at each end of the fiber trunk between buildings with one end connected with straight thru serial connection to Tripp lite port and the other end connected with rollover to Cisco Switch. This configuration worked fine in my lab with just like a 10 meter fiber patch cord between the two converters and default Cisco and Tripp Lite console port settings.
But now that I have implemented it in the real scenario with the fiber run about 1 mile away; not working so well.
Even though Serialcom says convertor is good for distances of 12.4 miles.
I am able to make a connection to the switch after authenticating through the terminal server. However, it takes a very long time 3-5 minutes to return the switch login prompt. However, the switch login prompt just scrolls by and will not stop to allow entry of the password. It just repeatedly scrolls, as if someone is enter password but nothing being typed.
Both ends of the connection are set at 9600-8-N-1. I have experimented with the baud and stop bits settings to no avail, and either never returns switch login prompt or just does the same thing.
I not sure if the is a line/Fiber quality issue or Serial setting issue causing the problem; and not much of an expert when it comes to serial connections; and serialcom folks no help.
If anyone have any insight or ideas in terms of setting/configuration that could be causing this and or tweaks. I would be much appreciated.
