I am using a Radix make 16 channel temperature scanner which communicates with host computer with RS485. I have used a RS485 to RS232 converter in between. The terminals available on the scanner are the following:
D+, D-, D+,D-, RS485 Ground
The teminals available on the converter are D+,D- only, and a 15 pin DSUB connector on the other side. I have connected only D+ and D- on the scanner to the D+ and D- on the converter. I connected the DSUB connector to the COM1 port on the PC.
I am using a proprietary Labview based utility provided by the vendor. But it says the device is not communicating.
Can anybody point out what is the mistake?
Also, is there a definite way of knowing if the com port is working or not?
Also, if I don't want to use the proprietary software given by the vendor what should I do?
