Question:
I am running RSLinx Pro (v: 2.40.01), with RSView32 (v: 6.30.17) and my display has no data. My driver (ETHERNET) is properly configured and browsing. My topic and channel are set. Node is set to topic. My tag monitor is returning stale and error messages. I tried everything: created new Node (OPC Server-local). My question, should the controller key be set to RUN or REM (remote)? Do I need to configure DCOM. My setup looks like this:
Channel: 1
Network Type: TCP/IP
Primary Communication Driver: AB_ETH-1
Active Driver
rimary
Data Source: OPC Server
Name: Chris (enabled)
Server Name: RSLinx OPC Server
Server Type: Local
Access Path: (blank)
Tag Database (added)
Scan Class (default)
Channel: 1
Active Driver
Server Type: Local
