RSLogix bitmap pasting
Anthony Kerstens
I've just discovered, quite accidentally, that in RSLogix 3.01.09.02 when you select a rung or individual logic object and hit control-c to copy, you can paste that selection as a bitmap into other windows programs. If you have screen
xrefs turned on, it includes that too. However, it seems to only work if a single rung, or single ladder object is selected.
I've been used to cutting and pasting text to/from RSLogix, but was surprised by this. Can anyone try this to see if it works in newer versions? Especially for multiple rungs or
multiple ladder objects?
Anthony Kerstens P.Eng.
H
Hutchinson, Ben [LFS]
I can confirm that this still works in RSLogix 5 v.4.00.00.64. You are still limited to one rung at a time for bitmaps or metafile pictures.
Multiple rungs only produce mnemonics (straight text).
Ben Hutchinson
Johnson & Johnson
Michel A. Levesque, ing.
Hi List,
Anthony Kerstens mentionned the bitmap rung pasting from RSLogix 5 to any other Windows programs.
I have RSLogix 4.00.00.64. I checked this out and you can paste bitmaps as well as enhanced metafiles of a single rung.
You can paste the unformated text of a rung and of multiple rungs into other Windows programs.
Going on step further, you can copy and paste rung(s) from RSLogix 5 or 500 or 5000 into any other RSLogix 5, 500 or 5000. Naturally you must verify the rung(s) for proper addressing afterwards. This makes migrating between SLC or PLC or ControlLogix a snap.
Michel A. Levesque eng., mcp
Directeur Bureau Montreal
AIA Inc.
Anthony Kerstens
Thanks to all who responded. I don't know where
I'll use bitmap pictures of logic, but maybe my documentation will benefit from it.
W
Anthony,
I have the exact same version you do, so I can't help you with your exact question. However, you can copy the entire active window into the edit
buffer by pressing alt-shift-PrntScrn. Perhaps you already know this, but there may be others who can benefit from this. I've used this a lot for generating documentation. You can paste the buffer into paint, crop the area you need, and then save it as a JPEG or BMP.
Willy Smith
Numatics, Inc.
Costa Rica
