Has anyone done any conditional programming with RSVIEW Studio alarming such that if alarms existed, and were unacknowledged, a particular bit would only be set if that particular alarm were of a high enough severity?
I know this sounds logical and simple, but I can't seem to find a method to this madness through utilization of the propriatary software. I am essentially trying to dial out with an autodialer using an RSVIEW trigger IFF the above conditions are met. The HMI will trigger a bit in a Controllogix 5000 PLC which triggers the autodialer after a predetermined TON sequence.
Any help on this would be much appreciated.
Thanks,
Adam
Thanks,
Adam
