Hello, so I'm having some issues with a few rtds reading in occupied spaces. Several local pocket temp sensors are reading 7 deg higher than the readout on our distech controller. These are 10k type II @77F, it says on the bags of all of these. So to troubleshoot, I took a 10k resistor and put it across the input on the controller and got 70F solid. I then went to location and removed he rtd, and replaced it with the same 10k resistor, also got 70F again. Now i've run into this before, and I need a few more opinions here, should I see the 70F or 77F on the controller readout? The controller is configured for 10k type II. (in fact all of them are here). This has happened at other locations here. What is right? Right now I put in a 7deg offset in the controller.
