Sample code to connect via MODBUS RTU
  • Thread starter Francisco Gonzalez
  • Start date
F
Francisco Gonzalez
I need to connect to PLC (PM172) but always receive the same response: time out.
I'm using the software libraries from Ricardo Saat, but i don't know if i'm not doing good.
If i use other components (not free), the result is ok. But i can't pay them. I have to develop a component very simple, but this component has to connect every second to PLC.
Have any one any idea? Can anyone send me source code in Visual Basic or Visual C++ to connect with a PLC?
Thanks a lot.
P
Philippe Boudot
<p>Hi,
<p>few lines of C/C++ (windows), used to calculate CRC and
send a request... Perhaps it could help you.
<p>Regards
<pre>
HANDLE hCom;
COMMTIMEOUTS lpTo;
COMMCONFIG lpCC;
unsigned short no_com = 0;
unsigned short jb_tabcrc[256] = {
0x0000,0xc0c1,0xc181,0x0140,0xc301,0x03c0,0x0280,0xc241,
0xc601,0x06c0,0x0780,0xc741,0x0500,0xc5c1,0xc481,0x0440,
0xcc01,0x0cc0,0x0d80,0xcd41,0x0f00,0xcfc1,0xce81,0x0e40,
0x0a00,0xcac1,0xcb81,0x0b40,0xc901,0x09c0,0x0880,0xc841,
0xd801,0x18c0,0x1980,0xd941,0x1b00,0xdbc1,0xda81,0x1a40,
0x1e00,0xdec1,0xdf81,0x1f40,0xdd01,0x1dc0,0x1c80,0xdc41,
0x1400,0xd4c1,0xd581,0x1540,0xd701,0x17c0,0x1680,0xd641,
0xd201,0x12c0,0x1380,0xd341,0x1100,0xd1c1,0xd081,0x1040,
0xf001,0x30c0,0x3180,0xf141,0x3300,0xf3c1,0xf281,0x3240,
0x3600,0xf6c1,0xf781,0x3740,0xf501,0x35c0,0x3480,0xf441,
0x3c00,0xfcc1,0xfd81,0x3d40,0xff01,0x3fc0,0x3e80,0xfe41,
0xfa01,0x3ac0,0x3b80,0xfb41,0x3900,0xf9c1,0xf881,0x3840,
0x2800,0xe8c1,0xe981,0x2940,0xeb01,0x2bc0,0x2a80,0xea41,
0xee01,0x2ec0,0x2f80,0xef41,0x2d00,0xedc1,0xec81,0x2c40,
0xe401,0x24c0,0x2580,0xe541,0x2700,0xe7c1,0xe681,0x2640,
0x2200,0xe2c1,0xe381,0x2340,0xe101,0x21c0,0x2080,0xe041,
0xa001,0x60c0,0x6180,0xa141,0x6300,0xa3c1,0xa281,0x6240,
0x6600,0xa6c1,0xa781,0x6740,0xa501,0x65c0,0x6480,0xa441,
0x6c00,0xacc1,0xad81,0x6d40,0xaf01,0x6fc0,0x6e80,0xae41,
0xaa01,0x6ac0,0x6b80,0xab41,0x6900,0xa9c1,0xa881,0x6840,
0x7800,0xb8c1,0xb981,0x7940,0xbb01,0x7bc0,0x7a80,0xba41,
0xbe01,0x7ec0,0x7f80,0xbf41,0x7d00,0xbdc1,0xbc81,0x7c40,
0xb401,0x74c0,0x7580,0xb541,0x7700,0xb7c1,0xb681,0x7640,
0x7200,0xb2c1,0xb381,0x7340,0xb101,0x71c0,0x7080,0xb041,
0x5000,0x90c1,0x9181,0x5140,0x9301,0x53c0,0x5280,0x9241,
0x9601,0x56c0,0x5780,0x9741,0x5500,0x95c1,0x9481,0x5440,
0x9c01,0x5cc0,0x5d80,0x9d41,0x5f00,0x9fc1,0x9e81,0x5e40,
0x5a00,0x9ac1,0x9b81,0x5b40,0x9901,0x59c0,0x5880,0x9841,
0x8801,0x48c0,0x4980,0x8941,0x4b00,0x8bc1,0x8a81,0x4a40,
0x4e00,0x8ec1,0x8f81,0x4f40,0x8d01,0x4dc0,0x4c80,0x8c41,
0x4400,0x84c1,0x8581,0x4540,0x8701,0x47c0,0x4680,0x8641,
0x8201,0x42c0,0x4380,0x8341,0x4100,0x81c1,0x8081,0x4040
unsigned short jb_crc16(unsigned char *trame,short size,unsigned short crc)
short i;
/* crc est la valeur de crc reinjectee */
for (i=0;i<size;i++)
crc^=*(trame+i);
crc = (crc>>8) ^ jb_tabcrc[crc & 0xFF];
return(crc);
unsigned short jb_init_crc16(void)
return((unsigned short)0xFFFF);
unsigned short jb_end_crc16(unsigned short crc)
unsigned short tmp;
tmp=(crc << 8);
tmp|=(crc >> 8);
return(tmp); /* retourne la valeur de crc */
BOOL state;
void InitCom()
char str_com[10];
BOOL state;
sprintf( str_com, "\\\\.\\COM%d\0", no_com+1);
hCom = CreateFile(str_com,GENERIC_READ|GENERIC_WRITE,0,NULL,
OPEN_EXISTING,FILE_FLAG_WRITE_THROUGH,NULL);
state = GetCommState( hCom, &lpCC.dcb);
/* Initialisation des parametres par defaut */
lpCC.dcb.BaudRate = CBR_9600;
lpCC.dcb.ByteSize = 8;
lpCC.dcb.StopBits = ONESTOPBIT;
lpCC.dcb.Parity = NOPARITY;
lpCC.dcb.fDtrControl = DTR_CONTROL_DISABLE;
lpCC.dcb.fRtsControl = RTS_CONTROL_DISABLE;
state = SetCommState( hCom, &lpCC.dcb );
state = GetCommTimeouts(hCom,&lpTo);
lpTo.ReadIntervalTimeout = 10;
lpTo.ReadTotalTimeoutMultiplier = 2;
lpTo.ReadTotalTimeoutConstant = 100;
lpTo.WriteTotalTimeoutMultiplier = 10;
lpTo.WriteTotalTimeoutConstant = 100;
state = SetCommTimeouts(hCom,&lpTo);
state = SetCommMask(hCom, EV_TXEMPTY);
state = SetupComm(hCom,2048,2048);
void WriteBuffer(unsigned char* Buffer, DWORD size)
DWORD Event;
Event = 0;
unsigned short crc;
crc=jb_init_crc16(); /* initialisation du crc16 */
crc=jb_crc16(Buffer,size - 2,crc); /* calcul du crc16 de la trame */
crc=jb_end_crc16(crc);
//SWAP LOWER AND HIGHER BYTES. I DO NOT REMEMBER IF WE HAVE TO DO IT HERE OR NOT !!!!!!!!!!!!!!!
//crc=jb_end_crc16(crc);
Buffer[size-2]=(char)(crc >> 8); /* conversion du crc16 en chaine de 2 */
Buffer[size -1]=(char)(crc & 0xff); /* caracteres */
state = WriteFile(hCom,Buffer,size,&OctetsEmis,0);
while (!( Event & EV_TXEMPTY ))
state = WaitCommEvent(hCom,&Event,NULL);
void CreateRequest()
unsigned char BufferEmission[2048];
unsigned char BufferReception[2048];
DWORD OctetsEmis;
DWORD OctetsRecus;
BufferEmission[0] = 1; // Slave Number
BufferEmission[1] = 3; // Function
BufferEmission[2] = 0x38; BufferEmission[3] = 0xe2; //Address
BufferEmission[4] = 0x00; BufferEmission[5] = 0x1e; //Number of registers
WriteBuffer(BufferEmission,8/*size*/);
state = ReadFile(hCom,&BufferReception,100,&OctetsRecus,0);
</pre>
P
philippe boudot
<p>Sorry there is a mistake in the code.
<p>the correct function is:
<pre>
short i;
crc^=*(trame+i);
return(crc);
</pre>
<p>Regards
