I am running a function block in only one scan cycle in my Mervis main program. The output of this function block is a set of 8 int numbers. As I am running this FB only in one scan cycle, I am not able to use the outputs of FB in the main program because after the first scan cycle, the output values seem to reset to "no value".
How I can save the results of this FB in the program?
