A Thread Starter A.Kilani Mar 25, 2010 #1 I have a Premium PLC with Ethernet Port and have another Twido PLC with Integrated Ethernet Port and i need to make the premium PLC communicate with the Twdio PLC to read the Values. So how can i do this please
P Patrick Lansdorf Mar 25, 2010 #2 Hi there, Well, as I see it you have several options. Here are some: 1. Set up one PLC as Modbus Tcp master (client) and the other one as slave (server). 2. If you have an OPC client, you could set up OPC servers for the PLC´s... 3. If both PLCs needs to be masters, you could use a gateway such as: http://www.anybus.com/support/support.asp?PID=243&ProdType=Anybus X-gateway Good luck Patrick L HMS support
