U
Hi Folks,
I m a summer student working at a hydro generation company in North America.
I am missing a linchpin in my understanding of how a generator puts power on a grid. I have to confess, I am not sure what exactly what I am asking for.
Because in my most basic understanding: Voltage needs to be higher at your end to pump current (thus power) to the other end.
while it is very easy to understand the open circuit voltage of a generator that is off the grid: The windings on the stator are cutting the M lines of an rotating and excited rotor, a motive/tendency/voltage is created in the stator windings propelling charges to flow. But, since the endings are open, no charges are flowing in the stator, So the rotor is not experiencing any counter force from the stator at all.
But I have huge troubles of understanding once the current of the grid starts flowing in the stator, and the voltage of the generator (after Xs and Rs and the transformer) matches that of the grid.
Once you have the same current flowing in the stator from the grid and that same current flowing out of the stator back to the grid; And a matching voltage (to me it means no current should flow between the same potential at all), are we generating power or are we moving like a motor? or when the rotor is not even excited or rotating, the whole stator is just an big stationary resistor and inductor.
My understanding so far is that: 3 phase grid current in the stator winding will be manifested (as you add 3 phases of sinusoidal up as a function of angle and time) as a rotating magnetic field. the rotor as a magnet needs to try to rotate faster than that stator's field to experience a "drag force", and that drag force was neutralized by the water rotating the turbine. This understanding is only good "energy conservation" wise. It does not explain the voltage/current/power confusion I mentioned above.
Since we are here,
two more questions:
[1]
the load of the grid is really the amount of current flowing on it right?
[2]
is it possible for the grid current to be so low and your wicket gate to be opened so wide to have the rotor spinning faster than "60hz" (as in 1.5 hz for a 90 pole machine)
Since we are here,
two more questions:
[1]
[2]
