W
Hello all,
recently obtained a Wallboard, which is an LED display board (something you might see displaying the stock ticker, etc...).
There are three RJ45 connections on the back along with a bunch of jumper settings to control them...
There is a RS232/RS422, RS422, and a tcpip...
I have no software for the board... I contacted the manufacturer who pointed me in the direction of the company that created the 'custom' software to run the board. Long story short...I have to program this badboy on my own.
I am good in c and vb but have never done any programming like this...
Tried vb with the mscomm control connected to the RS232 serial port, but couldnt get that to work. I have checked all of my settings on both the jumpers & code (baud, parity, etc...) and it all looks right to me. I even played around with different settings to no avail...
Wondering if anyone has any experience, or any suggestions to get this thing going. I can send you code I have if you want...
note...I have a windows and linux machine that I can use to try to get it to work (based on your experience I can try either)
...and I do know for sure that it works cause when you power it up it runs some tests (lights up) and displays the current settings.
Thanks in advance for any help...
