Serial/USB Modbus to Labview
W
wakho
I am looking to control a TEMPCO TEC-9100 temperature controller using LABView and MODBUS protocol.
I am using a rs232-USB converter. When I use the software given by TEMPCO to control the machine, it works perfectly. But when I attempt to control the machine through Modbus I/O servers within Labview I cannot establish a connection. The attribute "Commfail"
is returning the value "true". Is this because of my USB converter?
<b>Note:</b> I am new to both Labview and Modbus so please be patient.
Thank you very much in advance!
Does your 'machine control' software use the TEC9100 RS-232 communications port?
What 'machine control' software is this? The only factory software the Tec 9100 manual:
http://www.tempco.com/Engineering/TEC100Series.pdf
mentions is device configuration software which uses a special cable that connects to a device programming/configuration port.
Do you use the TEC 99014 cable with your USB/RS-232 converter or an adapter that adapts the pins as shown on page 11?
