H
I am developing an ASP application with ActiveX controls and some COM objects for our client's intranet. We automatically retrieve field data from flow computers and store the data in an Oracle database, and then automatically download analysis to the flow computers when it is available. The EFM's are tied together using
Intellution FixDynamics SCADA system. The ASP application will allow users to select the database they want to connect to, and generate reports.
The problem I am having is getting information to flow between the Server and Client sides of the application. The specific questions I have are as follows
1. How do I access a "session" variable from the client side?
2. How do I get access to a server side variable from the client side?
An example would be, I have an ActiveX listbox control that is populated via a server side script. I want to use the value of the item selected by the user in a client side function.
Manny J. Hellstern
Sr. Consulting Engineer
Mustang Engineering
(713) 215-8380
[email protected]
Manny J. Hellstern
Mustang Engineering
(713) 215-8380
[email protected]
