I have an actuator with a temposonic positioner in it, which controls a servo valve (Moog). When a scanner tells the tempo where to position itself, the tempo tells the servo to respond in either direction until the desired position is reached. The problem I have is that, when the control cable is disconnected from the servo, there is fluid flow, and the servo will move. Now I have to null the valve. It is my understanding that if there is fluid flow, I have to null the valve. But I have been told that I am not supposed to do this. Please help me understand these servo valves better.
dan
iownthebruins at yahoo. ca
dan
