T
I have a Kollmorgen SERVOSTAR 603 Drive and Platinum DLL ICD10-100 linear motor. All of the classical modelling information is available via spec sheets. I form the transfer function, and I is as expected for a motor, but the actual system does not exhibit the same characteristics.
The model using classical methods shows the system as being a typical dominant second order system. The drive itself has a Bode feature, and the sine sweep produces a fourth order system with zeroes. I figured that this must been done due to the drive. That was the next problem I encountered, I could not make the drive a simple amplifier without rewriting the firmware. I also found a linear model that is second order that worked for a very small bandwidth and with vary small variation in the input gain. Is there any help with only this information presented?
