P
Desperate request for help with setting up and VPN connetion with ADSL to and Omron PLC equipped with ethernet card (CJ1W-ETN11)
Any form of reply is greatly appreciated.
Our client is using an relatively new Omron PLC, the CJ1W. Equipped with an Ethernet Card CJ1W-ETN11 which is connected to an ADSL router,he wants to approach it through internet using CX-programmer (Omron's programming software) on his local PC.
Although both our local Omron dealer and we have very poor (to none) experience with ADSL,it has been confirmed that the concept should work.
I've looked a little bit into the mattter. As far as I understand it, we have to set up an VPN connection to the remote ADSL router, on which the PLC's ethernet card is connected.
When defining the VPN connection, we have to enter the ADSL router's IP adress, and when connecting we have to enter the routers username and password. And then we should be connected ?>?
I know (but not by experience) that communicating with an PLC through ethernet with CX-programmer should be as easy as entering the IP adress of the Ethernet card at the communication properties in the software, and then connect.
So when I add these two actions it should work?
