The GTs in the plant I work at fails frequently on vibration, which leads to shear pin failure and high temp. on both the driven and non-driven end of the turbine.
B | 26MW TURBINE SHEAR PINS BREAKING ISSUE | Power Generation | 39 | |
3 | How an electronic shear pin work? | General Automation Chat | 0 | |
A | Flying Shear to cut steel | Motion Control | 3 | |
H | Flying Shear Position Control | Motion Control | 26 | |
E | Rotart Shear cutter into Metal sheet cutting | General Automation Chat | 6 |
