Siemens Bits to Integer Conversion
dschmidt
I have a series of bits that denote alarm states inside the PLC. The PLC uses the alarms states for its internal logic. I'd like to monitor these alarms in a SCADA system as an integer. I can unpack the integer and inspect each bit in the SCADA system. How can I pack the bits into the integer using Siemens PLC ladder or function block logic?
I would assume your SCADA system can access at least one word in a data table.
You haven't stated which Siemens PLC but in ladder format it could be one rung for each alarm bit.
the equivalent to get/put statements, one for each bit.
The same idea applies to any other PLC not just Siemens.
