I am working on a project which requires the communication of Siemens S7 300 PLC with IFIX 3.5.
At the moment the PLC is communicating with WINCC using MPI Adapter. Now the client wants to change HMI to IFIX3.5. Can i use the same MPI adapter with IFIX3.5? If yes then is there any configuration or i just have to install the card and it will work with IFIX3.5. Will i be able to see the driver in the IFIX3.5 drivers list? At the moment i have only MPI Adapter Driver that comes with the Adapter itself. Do i need any other driver to communicate with IFIX3.5?
It is very urgent matter!!!
