L
Where can I find wiring and software examples of the Siemens Siwarex U module?
My application requires the wiring of two scales (load cells) to determine the tare and net weight of the product during the filling process. I am using the Siemens TP170B touch panel to enter the weight setpoints.
Is there a special function block I can use to convert the scale load cell reading into kg, in order to control the filling valve? Which is the most accurate and convenient method to control the setpoints via the Simatic S7 software?
Thank You.
Thank You.
