Let's say your 150mv source is most accurate driving a 10k ohm load. If you put a 3.33k and a 6.66k resistor in series across the source, with the 3.33k on the signal and the 6.66k going to ground, the voltage across the 6.66k would be 0-100 mv ground referenced.
