T
Repected sir,
We have use the temperature + Humidity transmitter (two wire loop transmitter) which gives 4-20 mA output, distance between transmitter and controller approximately about 150mt, and wire used for that transmission is screen shielded cable, SMPS used for excitation voltage makes two wire loop (24v DC, 2 Amp). Now our problem is we can't get the proper signal at controller end.
please suggest the solution which gives the output continuously and accurate. please do the needful.
regards,
tejas
regards,
tejas
