In online mode (CPU 315-DP), big FC networks (with large number of FBD/STL blocks) are only partially coming in online. Whenever open a FC and select online, always upper blocks of the big networks are showing online, where as its lower blocks show offline. Once we click lower block, it will come in online and upper block goes offline. Networks having small blocks have no such problem and they are always coming in online completely.Other unit PLC with simatic-7 (CPU 315). In online mode we are not facing this type of problem and even more than one net works come in online simultaneously. We are using simatic field PG with same setting for both PLC.
PG/PC interface for 315-2DP PLC is CP5611 (MPI)
PG/PC interface for 315 PLC is CP5611 (MPI)
