SIMATIC PLC Program
N
Nijamudeen
Dear Sir,
I am doing a machine run/stopped time monitoring project for our machines through my Desktop PC. This project will help us, whether the machine is running or not and calculate the total run/stopped time for a month or year. And we do have around 15 machines in our factory. And I have S7 300 CPU, Input and Output modules and licensed SIMATIC Step 7 software also. In SIMATIC Step 7 software there are SFC2, 3 and 4 available for monitoring the connected equipment run hour. I have tried these SFCs for a single machine. But this is not working. In this regard, can you help me to do the correct procedure for to create a program? Or Is there any software available to fulfill my requirement?
I am awaiting for your reply.
Thanks,
Nijamudeen
Diego Montes
Dear Nijamudeen,
I work with siemens since 1996. I never use the SFCs you mention, instead I make a little minutes counter program. Easy, so I can write the example in AWL:
//First a time base tick, triggering a timer //automaticaly every minute
UN M10.0
L S5t#1m
SE T10
U T10
= M10.0 //a Rising Edge here every minute
//Now the counting condition for machine 1
U M10.0 //minute tick
U (machine running signal)
SPBN MAC1
L MD 20 //Use a DINT to count minutes
L L#1 //increase MD20 by 1 every minute
+D
T MD 20
MAC1: NOP 0
...That´s all. You can divide miinutes by 60 to get hours in your HMI/SCADA or simply look the register with a VAT in Step7
Diego Montes
Siemens Certified Integrator
Motion Control Solution Provider
Ken Emmons Jr.
You could also have your machine keep track of downtime ina timer and have some database connectivity software (Siemens must have a solution for this...) monitor this timer periodically. I'd look into what hardware and software you need to have data collection from the S7 CPUs at a company wide level.
KEJR
