We have a Sinus Penta VFD that's running a brake dyno that we use for testing brakes for racing. 125HP motor connected to about 1200lbs of counter weight. Our cycle is speed up, motor off, brake with our attached caliper down to preset rpm, release, then ramp back up.
The problem is that we are getting a voltage spike to the dc bus on our ramp up. Right before the max speed.
We have installed a brake resistor and changed the parameters as per instruction from the technician in Italy. It's still overvolting. It's like it's not throwing the voltage to our resistor at all. We have a line reactor hopefully coming on Monday. Our building is an old textile factory with 600v service, that is actually about 622. We hope to drop it to about 590 and clean up any noise in the supply.
We've tried everything from changing accel/deccel ramps and running on speed control vs torque. We even changed the rubber coupling from the motor in the chance that it was worn out.
We have been dead in the water for a week and are losing money daily. Is there anyone here who has extensive knowledge with VFD's used to run brake dynos? Specifically, the Sinus Penta sold by Teco Westinghouse. We have talked with every local rep/tech that claims to know our problem but how we are using this drive is uncommon. And because of our voltage, we ordered the drive from Canada in hopes to save money as to not need a transformer to drop the voltage.
Any help would be greatly appreciated.
Jake
Jake
