Hi:
I have some SLC500 modules in stock that I want to test to make sure that all the channels work properly.
Need something fast and easy to enable a quick test to ensure that all channels work properly.
Modules I have are as follows:
NI16I
NI16V
FIO4V
NO4V (have got this one figured out)
NO4I (have got this one figured out)
Want to drive the inputs with the outputs and compare that they are both close (within factory specs of resolution).
Is probably only a couple of rungs and simple for someone that has done it before.
Thank you:
Bruce B
NI16I
NI16V
FIO4V
Thank you:
Bruce B
