WARNING: potential newbie question below. If I am just being dumb and missing something, go easy....(;^ }
Jiri,
Looking through the code for the SMM, I was looking at where the data point is validated in plc_get() and plc_set(). There is a call to
check_pt_magic(p). If I am reading the function correctly, it looks as though the application will dump out if the data point is invalid. Can this be caught and given back to the module as an error, allowing the module to try to handle the problem? The reason I ask is that I would potentially see some debugging tools that the 'programmer' could use to locate these type of
problems.
I realize that since we are passing a u32 right now, it would be hard to indicate an invalid data point. I just thought I would bring it up.....
Thanks,
--Joe
LinuxPLC mailing list
[email protected]
Jiri,
problems.
Thanks,
--Joe
[email protected]
