R
Hi, I need some help here. I am building a gauss gun and need a solid state relay switch because the mechanical switches have such a high power loss. I have it hooked up on a 50volt power supply and am using 3, 50volt 4700 uF capacitors. I also have around 6.5 meters of 14guage .00806 ohms/meter copper magnet wire. If you do the math, with I = V/R, you see that I = 50/.052 = 954 Amps when the capacitors are discharged. I need help in finding an affordable/(CHEAP =)) relay or solid state power switch for my gauss gun.
Thanks for the help,
Ryan
Ryan
