anyone who knows about special parameter
000-006 in fanuc 6m control. what is it??
plz tell me..
plz tell me..
G'day all, first post for me but i doubt it will be the last lol. I know this is a very old post but we have just purchased an old Matsura with this control and i tried changing the first 5 parameters but it wont change. Is there a special code/ sequence to be able to change the fixed parameters?PARAM_INFO BIT_NO DESCRIPTN KEY
PARAM 000 1 T/M CIRC. INTER BY RAD.
PARAM 000 2 T/M ADD 16 OFFSETS MEMORY
PARAM 000 4 T/M CSS B (ANOLOG OUTPUT)
PARAM 000 5 T/M G20/G21 SWITCHING (INCH/METRIC)
PARAM 000 6 T/M REF. POINT RET'N (2ND) 6M 0 RETURN B
PARAM 000 7 T/M REF. POINT RET'N (1ST) 6M 0 RETURN A (MANUAL,G28
PARAM 001 0 T/M G90,92/94 CYCLES 6M ADDITIONAL AXIS @SIM CONTROL
PARAM 001 1 T/M AUTO TOOL COMP. 6M ADDITIONAL AXIS CONTROL
PARAM 001 2 T/M CHAM. AND CORNER RADIUS.6M SIM. 3 AXIS CONTROL
PARAM 001 3 T/M TOOL NOSE COMP. (RAD). 6M CUTTER COMP C
PARAM 001 5 T/M MULTI CYCLES. 6M S2/4-DIGIT BCD
PARAM 001 6 T/M M.P.GENERATOR
PARAM 002 0 T/M AUTO ACCEL/DECEL. FOR FEED
PARAM 002 1 T/M STORE STROKE LIMITS 2 AND 3
PARAM 002 2 T/M RADIUS PROGRAMMING 6M F1 DIGIT FEED
PARAM 002 3 T/M STORE STROKE LIMIT 1
PARAM 002 5 T/M ** TAPE INTERFACE
PARAM 002 6 T/M INCREMENTAL OFFSETS
PARAM 003 1 T/M G10 OPTION 6M OFFSET DATA FROM TAPE
PARAM 003 3 T/M ** ISO INPUT
PARAM 003 4 T/M CLOCK DISPLAY 6M RUN HOUR DISPLAY
PARAM 003 5 T/M RAPID TRAVERSE OVERRIDE
PARAM 003 7 T/M PC MODEL B.
PARAM 300 0 T MACRO A OPTION
PARAM 300 1 T MACRO B OPTION
PARAM 300 2 T RESTART IN PROGRAM
PARAM 300 3 T G31 SKIP (NO MOTION)
PARAM 300 4 T AUTO CO-ORD. SETTING.
PARAM 300 7 T ADDN. BLOCK DELETE
PARAM 301 1 T/M MESS DISPLAY.6M EXTERNAL DATA I/P, ALARM MSG
PARAM 301 2 T/M 80/320M MEMORY (PART PROGRAM STORAGE) 6M 125 PGM
PARAM 302 1 T/M VAR. LEAD THREADCUTTING 6M G60-UNIDIRECTION POSN
PARAM 302 2 T DIRECT I/P OFFSET VALUE
PARAM 302 3 T MIRROR IMAGE.
PARAM 302 6 T WORK CO-ORDINATE SETTING
PARAM 302 7 T OFFSET VALUE COUNTER I/P
PARAM 304 2 T TOOL WEAR/GEOM.
N0100 T/M SOME OPTIONS REQUIRE ADDN PROMS-MACRO
N0090 T/M SOME OPTIONS REQUIRE ADDN PROMS-TOOL WEAR/GEOM.
N0110 T/M BOARDS- MEMORY OPTIONS
N0019 T SETTING PARAMETER
N0020 T/M 1)PARAMETER WRITE ENABLE SWITCH "ON"
N0021 T MODE SWITCH TO "MDI" OR ESTOP STATE
N0015 TO CLEAR MEMORY POWER ON 'O'AND 'DELETE'KEYS
N0022 T HAND LOAD PARAMETERS 0- 4
N0023 T HAND LOAD PARAMETERS 300-302
N0024 T HAND LOAD PARAMETERS 310-313
N0025 T HAND LOAD PARAMETERS 340-341
PARAM 000 0 6M CIRCULAR INTERPOLATION STD G02 G03
PARAM 000 3 6M SPINDLE SPEED 12 BIT OUTPUT CSS A
PARAM 001 4 6M CUTTER COMPENSATION B
PARAM 001 7 6M TWO DIGIT DESIGNATORS T2/T4 TOOL FUNCTIONS
PARAM 002 7 6M EXTERNAL DECELERATION
PARAM 003 2 6M HELICAL INTERPOLATION
PARAM 002 4 6M THREADING AND SYNCROUS FEED
PARAM 003 0 6M PART PROGRAM CHECKING
PARAM 003 6 6M STORED PITCH ERROR COMPENSATION
PARAM 004 0 M TOOL LENGTH COMP. (G43,G44,G49)
PARAM 004 1 M TOOL OFFSET (G45,G48)
PARAM 004 2 M CANNED CYCLES B (G73,G74,G80-G89)
PARAM 004 3 M CANNED CYCLES A (G80,G81,G83,G84,G85,G86,G89)
PARAM 004 4 M CIRCULAR CUTTING
PARAM 004 6 M SND AUXILARY FUNCTIONS B-CODE 3 DIDGITS
PARAM 004 7 M REMOTE TYPE POSITION DISPLAY
PARAM 005 0 M EXTERNAL WORK NO. SELECT
PARAM 005 1 M
PARAM 005 2 M
PARAM 005 3 M TURRET INDEXING FUNCTIONS
PARAM 005 4 M FT CENTRE H ATC SPECIAL ATTACHMENT
PARAM 005 5 M FT CENTRE D/E ATS SPECIAL ATTACHMENT
PARAM 005 6 M ROBOT INTERFACE
PARAM 005 7 M NIBBLING CYCLE (WOODPECKER)
N0009 CONTROL
N0011
N0016
PARAM 004 5 M SCALE FUNCTIONS (MAGNESYNE-OPTISYS)
N0026 ** CHECK SETTING DATA ISO/EIA ETC. **
N0026 T/M
PARAM 300 6 M 3RD/4TH REFERENCE POINT RETURN
PARAM 300 5 M TOOL LIFE MANAGEMENT CONTROL
PARAM 301 0 M AUTOMATIC OVERRIDE
PARAM 302 0 M WORK COORINATE SYSTEM SETTING - G54-G59
PARAM 000 3 SPINDLE SPEED 12 BIT OUTPUT CSS A
PARAM 005 1 M
PARAM 005 2 M
N0009 CONTROL
N0011
N0016
N0026 T/M
dear hiHi,
the parameters from 000 to 006 are the option parameters of the FS6. If you want a list please sent me your email adress to
[email protected].
Frank
H | Mitsubishi Special Type Inverter | General Automation Chat | 0 | |
K | Special coating on rotors | Power Generation | 2 | |
B | A special tools in MK VI | General Automation Chat | 5 | |
D | How to configure the Tag address for special module A616AD | Programmable Logic Controller - PLC | 0 | |
J | Fanuc 6m special parameter | Programmable Logic Controller - PLC | 0 |
