Y
We need to select the best command for a servo drive for CNC application. The options are: speed or torque or pulse-direction command. In this application we are going to use motion controller that can generate the above commands and we wonder which of them will generate the best performance in terms of speed ripple? What factors do we have to consider when selecting the control method?
What is the common solution at CNC application and why?
