Dear all,
We are having 3 nos of Siemens SGT400 type gas turbine to fulfill of our plant power requirements.
In that, one GT we are having a unsolved issue that is, While giving Start Command/Timed spin or whatever we are getting a alarm as "Starter motor failed to turn GG Shaft" after that starter motor gets stop command...
This is happened once we were given a normal stop command to that machine when it was running smoothly while the machine was in coasting down we got a first alarm as "Automatic spin at shutdown <b>disabled</b>" thereafter only we got a alarm "Starter motor failed to turn GG Shaft"
We are suspecting that the logic for automatic shutdown is disabled somehow and the same to be we wants to enable.
I'm looking forward from you all a meaningful solution for this issue...
(GG Shaft- Gas Generator Shaft)
Thanks & regards,
John
Thanks & regards,
John
