Square D Micro-1 & Program Loader User Manual
X
x_cinnmil
Hello, I recently picked up a used Micro-1 PLC unit with the Program Loader unit. I believe that this will allow me to enter a ladder program w/o any additional software and cables. I would appreciate some help in verifying this and / or
getting a copy of a user manual on hoe to use the program loader to enter programs if it can be done. Thanks
Doug Homberg
Greetings!
I believe the Square D Micro 1 is actually a private labeled version of the Idec Micro-1. It had an external program loader and used Clip (?) software for programming from a pc. Please advise and I will check to see if I still have this kicking around my office. Do you have the programming cable?
The loader will allow you to enter your ladder, but it is torture..
E-mail me and I will try to help.
Thanks!
Doug
[email protected]
I found a complete downloadable version of the user manual complete with info on using the program loader. It was on IDEC's website in case
anyone else needs a copy of the manual. Like the other reply mentioned, it does look cumbersome to use but it does probably work. Thanks for that reply.
