Hi all,
First post here.
I am working with a F5 and MKVI control system. We observed the SRV hunting and on further investigation found one channel on the TVSO had failed (Servo Output "T"). Initially we suspected this caused the issue but later found that the Suicide Relay was active for this channel, therefore this could not be the source of the problem. I calibrated the valve and at 0&100% everything looks good, however when i then use the Manual Verification the valve over shoots its setpoint and then starts to hunt. I have adjusted the Reg_Gain but there is no real observed change.
Any suggestions on troubleshooting is much appreciated.
First post here.
