Hello there, this is my first post, i want to buy the Phenix Loss Core Test model CL60B, but it needs 480 volts single phase and 60 kVA to work, i don't have that voltage, so I want to try something; I'm fixing a power plant of 230 volts three phase of 115 kVA, and I would buy a step up transformer to have de 480 volts, and I would feed the Loss Core Tester with only 2 phases, I now that the Generator it has to be bigger but I only need to test a motor of 2000 HP, (The Tester that i want to buy is to test motors of 2500 HP) so the charge i won't be the entire 60 kVA, it would be around 50 kVA, so my question is: Do you think that it would work? How many kVA the step up transformer it has to be?
Thanks for your help
