P
In Steam Turbine Applications, where we have Main & Stand By Lube Oil Pumps, do we stop the Lube Oil Pumps on Discrepancy (between command & Feedback).
If YES, is it necessary to do that way?
Consider that there was a discrepancy (false discrepancy) on Pump A and STOP command is sent to Pump A and Pump B starts. Due to some reason, if Pump B also fails to start, then we will have a Low Lube Oil Pressure on the header and this would TRIP the Turbine.
