T
Hey all you control nerds,
We are running InTouch 5.6b (Servicepack 2) under Win95 and have about once in a month the following problem with the Windowviewer (View.exe) . Intouch is communicating with a Siemens S5 via Profibus FMS. On the PC we are running a Profibusserver from Softing V4.0.
InTouch 5.6b is also communicating via NetDDE with another PC.
The following message pops up:
1. "PROFIBUS string not found: 24417"
OK ->
2."NETDDE string not found: 24417"
OK ->
3. "WINDOW VIEWER OUT OF MEMORY - allocate failed"
OK ->
4. "Assertion Error - Make note of Error File ndpopup.c Line 667 -
CONTINUE YES/NO",
YES -> "WINDOW VIEWER OUT OF MEMORY - allocate ...,
OK ->"Assertion Error - Make..."
NO ->"VIEW close/ignore",
ignore ->"Could not find/load real-time trend",
OK ->
Reboot PC-> System OK!
We have different types of error messages regarding this problem. But every time the problem occurs the "String not found" message is
between all the messages we receive.
We already dropped a note to Wonderware. They unfortunately have never heard of the String not found problem. They suggested to define the virtual memory like they advised in their Tech Note 90 (Configuring Virtual Memory Settings to Avoid "Out of Memory" Errors and System Problems) Unfortunately the changes did not help. Has anybody of you already faced the same problem?
Thomas
OK ->
OK ->
OK ->
CONTINUE YES/NO",
OK ->
Thomas
