P
My company builds machinery that always includes a few blowers. When our PLC gives these blowers the “Start” signal, we want to have confirmation that each blower is actually moving air. (For example, to make sure a damper has not failed in the closed position or a belt has broken).
Currently, we use Dwyer 1910-00 Compact Low Differential Pressure Switch (with an operating range of 0.07-0.15” w.c.). These pressure switches have a high pressure port and a low pressure port. We run a metal air tube from the high pressure port into the duct at the blower exit, and we angle this air tube so that the blower blows right into it. We leave the low pressure port open to atmosphere. Even though the operating range of this pressure switch is the lowest I could find, we always have trouble getting these to work at lower blower speeds.
I was wondering if anyone could recommend a different way for me to confirm blower air flow that might be more sensitive to low air flows than the differential pressure switch that I’ve been using. (I just want a discrete switch that will tell me if air is moving or not – I don’t need an analog air flow measurement).
Any advice will be greatly appreciated.
Thanks in advance,
Paul
Thanks in advance,
Paul
