Hi.
I need to take input from some sensors, which will provide digital signal of TTL level. Each of them will be either On (High) or Off (Low). I don't want to use any Data Acquisition Card or Digital I/O card for it, instead I want to use the parallel port.
Each sensor will have its own battery for providing TTL level signal to the computer. When the sensor detects something it will turn its line On (high). Since the computer will be continuously polling the parallel port to see the status of the sensors, therefore this change will be detected by it.
What i need is a circuit that can enable me to connect these sensors to the parallel port. They are digital (either on or off) and have their own battery to generate TTL level signal for computer. There is no problem with the software side, I can do it. I'm just confused about this circuit. I highly appreciate any help from you. Thanks.
Regards.
Regards.
