Gentleman,
Some time behind happened a rain with some atmospheric discharge (rays) that affected some equipments and boards of some processors. One of these boards was TCCA of the processor "C." In this plate we have some entrances of analogical signs that are the example described below:
TTRXTM_CMD C -CTBA-037 Exhaust temp match reference [??]
AFPCS C -CTBA-046 Inlet air total press transmitter [96CS-1]
PQL1 C -CTBA-049 After Conical strainer pressure []
PQL2 C -CTBA-052 Fuel filter suction pressure []
PQL3 C -CTBA-055 Before conical strainer pressure []
SPAJUV C -CTBA-058 96AM-TL1-CH1, 200-450 PSIG []
STAJUV C -CTBA-061 96AM-TL1-CH2, 400-850 deg F []
SDAJ2UV C -CTBA-064 96AM-TL1-CH3, 0-150 inH2O
L90PSEL_REM C -CTBA-070 MWATT SET POINT REMOTE []
I begin her we visualized the problem in the entrance L90PSEL_REM that receives a sign of DCS to control the load of the Unit Generated remotely. When we selected a certain potency for the Turbine, independent of which was this potency, the same was in "-21MW" always. Then we decided to check all of the physical connections and electric signs to try to find some flaw type, however we didn't find none fails related. In this case we substituted the board TCCA. When substituting the board we had an alteration in the potency and now it arrived in the plate with "43MW", however still independent of the load that I selected in DCS this load continued static in "43MW."
It was then that we used "Diagnostic Counters Display" to verify the amperage of entrance of the signs and we noticed that all the analogical entrances were locked (statics) and independent of the variation that happened in the field instrument, nothing happened in Mark V.
The amperage measurement was accomplished in the threads of entrance of the card and it was verified that there was amperage variation. However, when they were put in the card, the same ones didn't oscillate.
Observation: we already changed the CTBA board.
