Hi
I am required to design a program that will control the temperature of an oven. The operator will be allowed to enter a set point temperature in the range of 0 - 99'c via a thumbwheel switch. Upper and lower set point values are to be calculated which will be used to switch the oven on and off when the actual temperatures are reached. The actual temperature of the oven is to be displayed at all times during operation.
Oven spec:
Oven on/off control Y10
Actual oven temp Ch2 FX-4AD, position 1
Temp resolution 10'c/volt
Thumbwheel switch X20-X27 BCD format
Seven segment dislay Y20-Y27 BCD format
Up and Low set points +/- 1'c
If anyone can help me with any information I would be entirely grateful
Thanx
Mike
Oven spec:
Thanx
Mike
