TENV Variable frequency drives
A TENV motor can prevent the free exchange of air between the inside and outside of the case where it is installed. A TENV variable frequency drive helps to control that motor. It is especially designed to take care of that motor and ensure the proper working. If you are worried about any issues regarding TENV motor, it is better to check whether the vfd is working or not and there may be any other issues with the motor.
