Three channel serial analizer
G
Gabriele Corrieri
I search (from some months without any result) an software for analizyn three serial port at same time, but: two port run at same speed (38,4 Kbps) the third port runs at 187,5 Kbps, and has 485 levels. The most problem is the correlation of the three logs ... The third port is mounted on a PCI Card because the motherboard built-in port runs at 115,2 Kbps. I'd like a solution based on DOS or Windows, but if some people know a software that runs under Linux, or other operating system please tell me an advice.
Very thanks in advance.
Gabriele Corrieri
[email protected]
