O
Does someone has the pinout from handheld connector programer for TI305 PLC with CPU 330-37 (same as DL330 from automation direct)? could I use a different brand RS232/RS485 converter to communicate with the PLC and a PC?
L | Replacing 3/3 way Hand Lever Valve with 4/3 way Hand Lever Valve | Control Valves | 5 | |
S | IGV Hand Wash Effect on GT Output and Heat Rate | Power Generation | 10 | |
L | Download Program from Hand-held Programer to Laptop | Programmable Logic Controller - PLC | 0 | |
E | Hand Control Valves | Control Valves | 2 | |
M | Ti330 information | Programmable Logic Controller - PLC | 2 |
