P
My applixcation reads the state of inputs signals in 4x registers, so i need to transfer the input signals from the 1x register to the 4x register.
Using MOVE (a LD984 block) is quite easy, is there any other block or function similar in a IEC language (IL, STR, FCB,...).
I would also need to have the inputs siognals of the I/O bases, connected to the master using the I/O bus, in the 4x range of memory.
Is there any block to do that automatically?
