F
Assume that you have a good model of your process: transfer function of the process itself, of disturbances, etc. You design a PID controller. You add a filter, a compensator. Even more, you have a Multi Input-Multi-Output system, so you design a compensator to decouple the systems; which is, of course, a transfer function (or a matrix of transfer functions).
When it is time to implement this beautiful exercise on the process, you have a powerful cpu of Siemens S7-300 PLC (equipped with the PID module, I/O etc.).
Now, my question is: how do you put into the PLC all these beautiful transfer functions, filters, etc.?
AS far as I can see, I can input the P, I, D parameters in the PID block, but.. what if I want to add a filter, or a pole/zero cancellation?
Is there a way to accomplish it?
It is probably a naive question, but I have been thinking about it for weeks now, and can't figure out any solution.
Thank you very much for your kind interest!
