Transformer Neutral grounding
Alexander_giorgian
Hi all,
I want to Know, how can I calculate resistance or reactor for neutral grounding of one transformer with following data:
33Kv/7.07 KV
Yd
UK%=7.1%-9%
20/25 MVA
Phil Corso, PE
Responding to A. Giorgian's Oct 12, 4:20pm query... additional information is required:
1) Is the Wye connected primary, 33kV, supplied from an overhead transmission system?
2) Is the Delta connected secondary, 7.07kV, earthed via an earthing transformer?
Phil Corso, PE {Boca Raton, FL, USA}
[[email protected]] ([email protected])
Sushanta Halder
First you have to decide the earth fault short ciruit current to be limited to a value say 100Amp (equal to rating of generator gounding resistor current rating). Then the phase voltage will be appeared will be 33/1.732 kv. so the resistor value will be 33/(1.732*100)=X kohm.
