T
Does anyone on the list have any knowledge about a product that ABB Instrumentation produces called a "TransWedge". It's used for measuring flow rates. I'm wanting to tie this unit into a PLC to provide the customer with "flow rate" readings. What I need to know is:
A. What are the typical outputs? (Delta PSI, Static PSI, temperature)
B. What is the type of output? (analog, high speed counter)
C. How is a Chromatograph typical used with this unit? (dynamic or set data)
Thanks for your help, Tim
