W
I have a Bosch SVB3601L packaging machine with a Parker Digiplan BLX150B servo driver. After a normal shutdown of production the machine does not recognize the driver. I discover that the battery was over. I replace the battery but the driver shows fault. The most possible is that the program was lost because the battery fault. I have the driver configuration software (X150) in DOS but I haven’t the application program. I have an identical machine in the factory running OK. I want to know if can I upload the program of the driver on the machine that is running OK and download it to the faulty driver and also I need to know which is the communication port for programming. The driver has several.
